Laser cut parts
Posted by fireemblem20
Laser cut parts
October 24, 2012 06:23PM
Does anyone have a file of a drawing with the dimensions for how to make a laser cut frog, and a laser cut filament drive bracket?
Re: Laser cut parts
October 25, 2012 05:27AM
You should tell us for which exact machine.
Re: Laser cut parts
October 26, 2012 08:20PM
Its for the Reprap Huxley
Re: Laser cut parts
October 28, 2012 02:57PM
Which Huxley ? AFAIK, at least 3 vendors made one and each is different : emaker, techzone, reprappro.
Re: Laser cut parts
October 30, 2012 09:39PM
the reprappro
Re: Laser cut parts
October 31, 2012 04:48AM
Then the dxf files here should be what you need : [github.com]
Re: Laser cut parts
November 01, 2012 06:05PM
Also do you know if I will need optic sensors for the RepRapPro Huxley?
Re: Laser cut parts
November 14, 2012 02:10PM
Do you know what free program to use to view the drawings, cause i keep getting errors when i try to view them.
Re: Laser cut parts
November 15, 2012 10:21AM
Opensource inkscape is your friend for all vector drawing jobs.
Re: Laser cut parts
November 15, 2012 06:31PM
I installed Inkscape, but when i try opening the files it just shows a blank square
Re: Laser cut parts
November 16, 2012 05:21AM
Works for me :
open | download - frog_in_inkscape.jpg (63.7 KB)
Re: Laser cut parts
May 18, 2013 04:55AM
Im searching for the same lasercut frog. when i open the file i see a blank page. en when i open the solidworks version i get a unexpected file error...
Did you find the frog?
