Temperatur starts at 503 Celcius
Posted by fantom
November 30, 2012 04:35PM
Often - not always - at power up the temperatur "is" 503 degrees C and then it does not get hot. It ignores setting the temp. - the only way - so far - is to disconnect the hot end and reconnect it.
Is that a known bug with a known solution?
Re: Temperatur starts at 503 Celcius
December 31, 2012 03:57PM
What type of huxley do you have? Whats electronics/version are you using? What control software are you using (reprap host or replicatorg etc.)
January 01, 2013 02:39AM
TZ-Huxley, Pronterface.
January 11, 2013 06:15AM
I never experienced that, it seems like a bug happens in the hotend control daughter board initialization sequence.
I know no better solution than what you do. Do you need to cut the power to the mainboard for your unplug/replug "fix" to work ?
January 12, 2013 09:09AM
To me this sounds like a short in the thermistor wiring. A nasty one, which vanishes after re-plugging. Having a thermistor resistance of zero ohms gives very high temperature values.
January 13, 2013 06:16AM
It is not necessary to power down the mainboard, just disconnect the thermocouple board and reconnect. No doubt it is an initialization problem.
January 13, 2013 09:29AM
Dis- and reconnecting the thermistor doesn't initialize anything.
January 15, 2013 05:56AM
Well. The communication between the mainboard and the thermocouple-board must be restarted....There is no thermistor in the TZ Huxley.
