Doubt Regarding some error messages
Posted by pinto.chirayil
June 17, 2013 02:21AM
I am using RepRapPro huxley 05-03,I have printed some objects with this machine.After a long time again i used the machine while i giving the printing command it shows the error signal as MINTEMP triggered,EXTRUDER switched off. May i know the reason why it happened? Pls any one give solution for this problem.
Re: Doubt Regarding some error messages
June 17, 2013 05:50AM
Most likely a loose connection to the thermistor. If the connection is broken the temperature reading becomes 0 which triggers that error.
