Repsnapper or Slicer code for Techzone Huxley??? August 03, 2013 10:38PM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 04, 2013 03:57AM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 04, 2013 10:04AM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 04, 2013 11:42AM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 05, 2013 02:40AM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 06, 2013 03:27AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 06, 2013 03:48AM |
Re: Repsnapper or Slicer code for Techzone Huxley??? August 06, 2013 05:34AM |
#if MOTHERBOARD == 3 //#define MENDEL 1 // Comment out this if you are using a thermocouple //#define USE_THERMISTOR //#define USE_DS2760 #define USE_TECHZONETIPMANAGE #ifdef USE_DS2760 #define OW 13 #define OWTroubleshoot 13 #define ReadNet 0x33 #define SkipNet 0xCC #define RdReg 0x69 #define thermoTypeK //#define thermoTypeJ //#define thermoTypeT #endif // Set to 1 if enable pins are inverting // For RepRap stepper boards version 1.x the enable pins are *not* inverting. // For RepRap stepper boards version 2.x and above the enable pins are inverting. #define INVERT_ENABLE_PINS 1 // Set to one if the axis opto-sensor outputs inverting (ie: 1 means open, 0 means closed) // RepRap opto endstops with H21LOI sensors are not inverting; ones with H21LOB // are inverting. #define X_ENDSTOP_INVERTING true #define Y_ENDSTOP_INVERTING true #define Z_ENDSTOP_INVERTING true // Motherboard 3 driving Pololu microstepping controllers - 16 microsteps // Axis scaling in stepper-motor steps per mm of movement //#define X_STEPS_PER_MM 8.038 //10 tooth #define X_STEPS_PER_MM 10.047 #define X_STEPS_PER_INCH (X_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_X_DIR 0 #define Y_STEPS_PER_MM 10.047 #define Y_STEPS_PER_INCH (Y_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Y_DIR 0 //#define Z_STEPS_PER_MM 805.030 // had to be multiplied by 1.242189732 #define Z_STEPS_PER_MM 1000 #define Z_STEPS_PER_INCH (Z_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Z_DIR 0 // Stepper-driven extruder // E_STEPS_PER_MM is the number of steps needed to // extrude 1mm out of the nozzle. E0 for extruder 0; // E1 for extruder 1, and so on. //#define E_STEPS_PER_MM 0.9 // NEMA 17 extruder 5mm diameter drive - empirically adjusted //#define E0_STEPS_PER_MM 3.5 // original stock techzone value !!! #define E0_STEPS_PER_MM 172.0 #define E1_STEPS_PER_MM 17.6 // NEMA 17 59/11 geared extruder 8mm diameter drive // The temperature routines get called each time the main loop // has gone round this many times #define SLOW_CLOCK 2000 #endif
Re: Repsnapper or Slicer code for Techzone Huxley??? August 16, 2013 01:00AM |
