Infill Problem
Posted by ItsRyanBeck
Infill Problem
November 21, 2013 08:03PM
My RepRap Huxley has recently been printing the infill slightly offset to the shell of the print. This only happens on the left hand side, I have tried adjusting the left side of the printer so it is aligned properly but it hasn't seemed to help much.
Does anyone know how to fix this?
Thanks
Re: Infill Problem
November 23, 2013 05:46PM
Try to print some cylinder. If base is not round and you have offset of infill seams you gears on x-y motor are shaky/wobbly on the shaft. Try to put thin sheet metal between D profile of the shaft and gear. Also increase tense of the belts.
Hope that will help
