I'm trying to upgrade my printer with another cooling fan and I've recently purchased a 40mm 12v fan to mount on my Huxley. However, I've found that the 'fan' connection on the Melzi board supplies 19v. I've had a few ideas about what to do with regards to this:
a) Use a voltage divider to bring the 19v down to 12v. I guess this isn't such a great idea as it's quite a large voltage drop and I'm supplying a load?
b) Would setting the fan speed in Slic3r to less than 100% (say, 60%) effectively reduce the voltage for me using PWM?
Are either of the above options viable for the fan and safe to use? Does anyone have any other suggestions?
Thanks
Edited 1 time(s). Last edit at 07/06/2014 07:33AM by PatrickT.
