Huxley heatbed connect to Ramps 1.4 July 12, 2014 12:48PM |
Re: Huxley heatbed connect to Ramps 1.4 July 13, 2014 02:58AM |
Re: Huxley heatbed connect to Ramps 1.4 July 13, 2014 08:39AM |
Re: Huxley heatbed connect to Ramps 1.4 July 13, 2014 02:37PM |
Re: Huxley heatbed connect to Ramps 1.4 July 13, 2014 03:25PM |
Re: Huxley heatbed connect to Ramps 1.4 July 14, 2014 05:39AM |
Re: Huxley heatbed connect to Ramps 1.4 July 14, 2014 12:55PM |
Re: Huxley heatbed connect to Ramps 1.4 August 01, 2014 02:10PM |
3Dmaker4U
[reprap.org]
And in pins.h the assigned number is the number of the D-igital (or A-nalog) pin. For example, #define HEATER_BED_PIN 16 assigns pin D16.
You can use the I2C pins SDA/SCL, which correspond to D20/D21, but you have to make sure I2C function is not activated by default (which I assume is not, but you should better check) in Marlin.
Re: Huxley heatbed connect to Ramps 1.4 April 01, 2019 07:34PM |
