Huxley control board
Posted by Sean Eldridge
August 06, 2014 09:42AM
Hi everyone. I need to replace my circuit board on my Huxley 3D printer and was wondering if the circuit board for sale here would work with my printer:
[reprap.me]
If it doesn't work with the printer I was hoping someone would know where I might be able to purchase one for relatively cheap.
Thanks!
Re: Huxley control board
August 06, 2014 12:39PM
Sean Eldridge
[reprap.me]
Thanks!
The melzi is the stock controller for Huxleys (and Mendels) - from reprappro at least.
The answer is, yes. If it's different to your old one you may need to change the way wires connect (it uses screw clamps rather than header pins).
Hope this helps.
Michael.
August 07, 2014 04:35AM
Pretty much any electronics should work. Stepper motor is stepper motor, no matter which frame it's mounted in.
