Proximity sensor not providing anticipated output
Posted by mattie
July 27, 2015 04:04PM
This is my first post - and my first attempt to build a RepRap - so a warm hello to all.
I've got to the point where I have made a few test prints, these have not stuck correctly to the bed so was playing around with temperatures to try to improve things.
Sadly the proximity sensor - the IR versions provided as part of the standard Huxley Duo - has stopped responding as intended. I managed to zero in all 3 planes, but any attempts to zero in x (or, somewhat catastrophically, Z) result in the printer jamming into end of travel.
When commissioning, the proximity sensor returned the anticipated value of 950ish in pronterface when a piece of paper was placed in front of the sensor, but this has apparently dropped to 250. The voltages for the sensor connections (taken from the proximity sensor board itself) are quite a bit away from the desired - I get around 0.6V instead of the anticipated 1.53V when a piece of paper is in front. The Yellow voltage is also a bit out, but the blue and green are OK suggesting the sensor is correctly powered. The duet itself appears OK from the tests I've run.
Have I somehow broken the proximity sensor? I've had a few nozzle blockages which have required taking the hot end apart, so I worry I've banged it in the process - the sensor was OK for quite a few aborted test prints.
Advice on what to try would be much appreciated. I've contacted support, but perhaps best to wean myself off their assistance!
Cheers,
Matt
Re: Proximity sensor not providing anticipated output
July 27, 2015 05:12PM
One quick thing to check is that the sensitive face of the IR sensor (the black cuboid at the bottom of the sensor board) is still parallel to the bed. The sensor is mounted on legs, which can get bent if the sensor hits something.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
July 28, 2015 03:57AM
Thanks for comment.
I've checked the alignment, all looks good - I've removed the proximity board so I could it test it a little bit more easily, and so I can get the test sheet of paper squarely in front.
I'll have a check of the wiring loom, but checks of pin voltages at both ends of the loom suggest the problem is with the sensor.
