Thanks for the help ajm11. So you just drilled a hole on the side of the ABS guide?
A couple more questions for you:
- Why did you rebuild your extruder?
- What did you use for the bed?
-When I first start it, how will it know the length of the x,y, and z axis, theres no flag on the other side if you know what I mean.
-Any help on how to do initial software setup? Any documentation on all the settings?
I found these settings but its for PLA. I have ABS.
someone on the forum
My settings for PLA:
Extruder temp: 220 (issues in the melt nozzle so i run it high)
Extrusion Multiplier: 1.4
Extruded material width: .6
Extruded height: .4
Min/Max print speed: around 1800 (some blow out issues)
Z Printspeed: 50
No raft
Infill gap of 1mm
With repsnapper dont forget to edit the extruder temp set for the temp you want. It defaults to 75 when you generate the gcode
Thanks again
