Does the "Reverse" button work for anyone?
Posted by JLudlow
September 25, 2011 12:26PM
Hi Everybody,
We managed to get Repsnapper connecting with our Mendel, things are moving and heating up just fine so far! smiling smiley What I was wondering was if anyone is using the "Reverse" button beside the "Run extruder" button in the "Interactive control" area with any success. It doesn't seem to working here. I can get the extruder to run, but not reverse.
Thanks for any feedback!
Jacqueline
Re: Does the "Reverse" button work for anyone?
September 25, 2011 02:02PM
Works for me, may be related to your electronics/firmware ?
I use techzone monotronics (with their custom firmware).
Does it turn in the normal direction when you use reverse, or not move at all ?
September 25, 2011 02:46PM
Bonjour Deux Vis,
Thanks for your reply.
We are using the Techzone monotronics -with their firmware as well, which is supposedly the most up-to-date.
I just figured it out!! You have to have the reverse button in the "on" position and then you have to click on "Run extruder" - I thought reverse would just reverse on its own... silly me smiling smiley I seem to be answering my questions these days! At least if someone else has the same problem they will find this message, I hope.
Jacqueline
September 25, 2011 03:24PM
Fine, yes it's a toogle and you must still use the other button. The fact that the main button is a toogle itself doesn't help getting it I reckon.
