i an not a total newb to linux i can normaly get things i want installed but i seem to be running into issues trying to get repsnapper to install on my xubuntu systems that i want to be my main printing setup. from what i can tell i have everything installed but i get this message in the CLI when i try to start repsnapper
repsnapper: error while loading shared libraries: libreprap.so: cannot open shared object file: No such file or directory
but i have followed the instalation instrutions for librerap, but i am not sure if i need to do the last part of the install
By default, the files are installed under /usr/local/, but some distros don't
include it into the search path for dynamic libs (running a binary that links
against libreprap might reports something like "Can't find libreprap.so" or so).
There are two ways to fix that:
* Change the install prefix to /usr/ instead of /usr/local, which is not recommended
* Add /usr/local/bin to ld.conf by creating a file /etc/ld.so.conf.d/local.conf which includes only the line "/usr/local/lib"
** run "sudo ldconfig" afterwards
i dont get the same error they discribe, but i am sure i have it installed
mike-mack.blogspot.com]
