xubuntu instalation
May 01, 2011 10:10PM
i an not a total newb to linux i can normaly get things i want installed but i seem to be running into issues trying to get repsnapper to install on my xubuntu systems that i want to be my main printing setup. from what i can tell i have everything installed but i get this message in the CLI when i try to start repsnapper
repsnapper: error while loading shared libraries: libreprap.so: cannot open shared object file: No such file or directory
but i have followed the instalation instrutions for librerap, but i am not sure if i need to do the last part of the install
By default, the files are installed under /usr/local/, but some distros don't
include it into the search path for dynamic libs (running a binary that links
against libreprap might reports something like "Can't find libreprap.so" or so).
There are two ways to fix that:
* Change the install prefix to /usr/ instead of /usr/local, which is not recommended
* Add /usr/local/bin to ld.conf by creating a file /etc/ld.so.conf.d/local.conf which includes only the line "/usr/local/lib"
** run "sudo ldconfig" afterwards
i dont get the same error they discribe, but i am sure i have it installed
[mike-mack.blogspot.com]
Re: xubuntu instalation
May 11, 2011 07:26AM
On ubuntu 11.04 I had to change the lib path, by first calling "ccmake ." and change the directory to /usr/. Then it worked.
Building and installing:
* "cd libreprap"
* either:
** "cmake ."
** or "ccmake ." or "qcmake ." for changing the install prefix or adding the debug flag
* make && sudo make install
Remember to "cd" between installing libreprap and repsnapper, if not the directories will not be in the correct spot.
