Strange problem with Repsnapper
Posted by raijinspecial
August 08, 2011 07:59PM
I just finished building my Prusa and managed to tweak the settings in repsnapper to get some decent prints.
The only problem is the dimensions in the z-axis seem to be two times greater than is shown on the STL file or the gcode trace in repsnapper.
For example, when I try to print a prusa base vertex with foot, the holes for the threaded printed by the x and y axes are the perfect size and completely round. The the hole built in the z axis is oval and twice as wide as the xy hole. I dont know what I need to do to tweak this.
Thanks!
Re: Strange problem with Repsnapper
August 08, 2011 10:16PM
I'm starting to suspect that it is printing two layers for each one it should be printing, but I'm not sure how to tell in the code if its doing it.
Any thoughts?
August 09, 2011 11:48AM
Ok I printed a 40mm test cube.
It came out 50mm in the xy axes and 100mm in the z axis, what gives?
August 09, 2011 06:01PM
You haven't been doing your homework?
It sounds like you skipped the calibration step in firmware setup.
go to the IRC channel, and look for me (Wildseyed) there, and I will walk you through.
Make sure you have a digital caliper. We will need to take precise measurements.
