I am trying to figure out what extruder settings to use. I have been calibrating x, y and z axis movements to change in the firmware.
With the current version of Repsnapper if I hit the Run Extruder button my motor just vibrates. My RAMPS is set to 1/16 steps for all axes. Once I change the settings down to around 1600 mm the stepper finally moves. Any recommended setting from anyone?
I am only testing with PLA right now with temp around 195 and it does extrude but the settings are elusive as to what I should use.
Also I am using Sprinter as the firmware for the Mega 2560.
