Hi, I have a Mendel reprap with gen 6 electronics and Repsnapper software. All axes work well, for example when I send Y10 the real Y axis move of 10mm.
I have a problem, when I print an object, each layer is shifted about 5mm in the Y axis direction.
Look this photo (print_test.stl after 4 layers) : [
imageshack.us]
I think hardware and firmware works well because the first layer it's ok, it's possibile that repsnapper can't convert gcode correctly?
The only settings that I changed is "Downstream extrusion multiplier" because I have 1,75mm PLA filment insted 3mm.
Thanks!
