Hi All,
I've got my Prusa Mendel running ok with the titled software. Had a bit of a stepper motor heating problem. Needed to put a multimeter on the X-axis, Y- axis and Extruder motors and set the current to 0.5 amps each. I'm using Pololu 1200 steppers. At this setting my heating stays around 45-50 degrees C. The extruder and the heated bed are also working fine. Do I need to load skeinforge? if so, which version? If not, I think I'm ready to print. Can someone direct me to some info on what my next steps should be, Please?
Thanks
