I've been printing for a few weeks now and all has been smooth. Today I got around to changing my setup and installing the hotbed, but its no workin.
I'm working with RAMPS 1.4 and Marlin, although I went back and retested with Sprinter with no luck either. PSU should be big enough. 450W with two seperate 12V rails pushing 20A each. I've got 12V at the incoming terminals on both. If I turn on the fan or the hot end, I get red led lights and 12V on the terminals. When I turn on the bed, I get a big fat nothing. No LED, no 12 and no heat. Checked the onboard fuses and they both seemed to be ok.
So am I overlooking something in the firmware or is it in the hardware? I'll keep fiddling, just thought someone else might have some insight!
Thanks!
JW
Josh
//Prusa / RAMPS_1.4 & ATMega_2560 / Slic3r > Pronterface > Marlin / Luck
