Problem with endstops.
Posted by Rico
December 11, 2011 11:06PM
I am having an issue that seems to stem from the endstops. I did all the pre-flight checks and ran the test code, everything seemed to check out. After that I uploaded the newest Tonokip firmware. My hot end worked but all 3 of my axis didn't move. After 2 days of trial and error debugging, I found that if I switched ENDSTOPS_INVERTING to true I got movement, but as expected, they are inverted. Reverting them back gets me no movement whatsoever. Please help me!
Cheers,
Rico
Re: Problem with endstops.
December 12, 2011 05:21AM
You can edit your configuration.h file at the point of AXIS DIRECTION, use the configuration that let you right now move in one direction, and edit the axis direction to 1 if the current is -1, or to -1 if your current is 1.
