Extruder Resistor December 22, 2013 03:48PM |
Re: Extruder Resistor December 23, 2013 02:20AM |
Re: Extruder Resistor December 23, 2013 04:24AM |
Re: Extruder Resistor December 23, 2013 08:32AM |
Re: Extruder Resistor December 24, 2013 10:26AM |
Re: Extruder Resistor December 26, 2013 03:06PM |
Re: Extruder Resistor December 27, 2013 07:00AM |
Re: Extruder Resistor December 27, 2013 11:51AM |
Re: Extruder Resistor December 27, 2013 01:55PM |
Re: Extruder Resistor December 28, 2013 01:46PM |
Re: Extruder Resistor December 28, 2013 02:02PM |
Dala.horse
The new PC power supplies that are "Haswell" compatible completely removes all
the question marks that plagued older ATX power supplies. For instance the Corsair
CX430 is capable of supplying a very small 12V load only. The internal architecture makes
the old demand of minimum loads on all voltages obsolete.
Snipped from the data sheet: +12 V max 28 A, +5 V max 20 A, total load max 430 W.
A fan using 80 mA on the +12V as the only load gives voltages on all outputs that are all within spec.
(3,33 V, 5,10 V, 12,14 V, -11,61 V and 5,02 V on "flea power")
It's quiet and cheap too and you get all the other output voltages for free.
There's an external control pin for on/off like on all PC PSU's.
Re: Extruder Resistor December 28, 2013 02:40PM |
Re: Extruder Resistor December 28, 2013 08:31PM |
