WIKI blatantly and dangerously wrong? June 22, 2012 08:00PM |
Re: WIKI blatantly and dangerously wrong? June 22, 2012 08:04PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: WIKI blatantly and dangerously wrong? June 22, 2012 08:14PM |
Re: WIKI blatantly and dangerously wrong? June 22, 2012 09:34PM |
Re: WIKI blatantly and dangerously wrong? June 23, 2012 04:26AM |
Re: WIKI blatantly and dangerously wrong? September 04, 2012 09:18PM |
FROM REPRAP WIKI
Without D1 installed, or when the 12VIN is not connected, the Arduino gets its power from USB. If you want your kit powered without USB connected you need to solder in D1 OR connect VCC to your PSU.
The VCC pin can be connected to your ATX's 5Vsb to continuously power the Arduino from your ATX power supply. You will want to make sure that D1 is not installed or cut out. The Arduino is not designed to be powered directly on the VCC rail and the VIN pin at the same time.
The 5V pin in that connector on RAMPS only supplies the 5V to the auxiliary servo connectors. It is designed so that you can jumper it to the VCC pin and use the Arduino's power supply to supply 5V for extra servos if you are only powered from USB or 5V. Since there is not a lot of extra power from the Arduino's power supply you can connect it directly to your 5V power supply if you have one. You can also leave this pin not connected if you have no plan to add extra servos.
Re: WIKI blatantly and dangerously wrong? September 04, 2012 09:39PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: WIKI blatantly and dangerously wrong? September 04, 2012 10:06PM |
Re: WIKI blatantly and dangerously wrong? September 08, 2012 04:31PM |
Re: WIKI blatantly and dangerously wrong? September 08, 2012 05:53PM |
Re: WIKI blatantly and dangerously wrong? September 08, 2012 09:24PM |
