Servo connection
Posted by -DUS-
Servo connection
February 27, 2014 08:56AM
I have aquestion regarding the servo connections on the Ramps board.
It looks like I'm having a bad servo port on my board because My Ramps goes in to a startup loop after I power on the board. I found this to stop when I disconnect Z Servo (Servo 0 I believe?). I already tried with a replacement servo, but with the same results.
I tried connecting the servo to the X servo and Y servo port (although not active) and then you hear the servo twitch a bit when you power on like it normally does on the Z port, and then my ramps works normally.
I'm not an exert, but that makes me think the port could somehow have gone bad...
Would it be possible to chaswitch the Z servo port with the X (or Y) servo port in the Marlin frimware?
Any help is appriaciated.
Thanks! :-)
