Wiring of Ramps1.4 December 11, 2014 07:42AM |
Re: Wiring of Ramps1.4 December 11, 2014 09:26AM |
Re: Wiring of Ramps1.4 December 11, 2014 12:00PM |
Re: Wiring of Ramps1.4 December 11, 2014 09:11PM |
If you wire the - through D9, then anything else that is connected to D9 will need to be on in order to turn your parts cooling fan. Typically for a cooling fan on an extruder, it would be hooked up to an always on source, either the 12V Aux connector, or straight to the power supply. The parts cooler is then hooked up to D9 + and - connections.Quote
Georg99
So I can wire it with (-) of D9 and (+) from Aux 12V,
So it can be controlled, separately from the hotend cooler.
