Hello everybody
i am trying to make a delta 3d printer based on ramps and arduino mega 2560
the problem is that i can't get any stepper driver based on allegro chips because i cant find any allegro driver in my country (i live in syria)
so i decided to use stepper driver 1.2 because it is based on l297 translator and l298 H-bridge (i can find both in my country , and i will connect just the step and dir and enable pins between the driver and ramps)
but i found that the stepper driver 1.2 get enabled when it get a high (+5v) signal to the enable pin but the polulu drivers get enabled when it get a low signal in the enable pin
so should i add a logic Not-Gate (logic inverter) to the stepper driver 1.2 enable pin to make it work on ramps ?? or i can make it work without any modification ??
hope anybody can help me ...
