Understanding of electronics 5/10
Im using a mk2 heatbed
Ramps 1.4
Several different power supplys
Purchased
www.ebay.com]
Mirlin
Set headbed in config to 1? just says a 100k resistor same as the epoc 100k? i set both temps to 1
Im using Pronterface
Also these big guys get really really warm is this normal?
reprap.org]
Issue:
Mk2 heat bed heats fine up until 50c mark
It heats then dies off and cools down
Im assuming Im using a good power supply Pulled 2 out of 2 working computers to test both with same results
I have also hacked a xbox 360 power supply to supply just the volatage to 10a line while using pc power supply to power 5a line
xbox 360 power supply is rated at
203w 12v - 16.5A or another at 150 watt 12v 12.1A
MK2 bed Tests at .8-.9 ohms think this is my problem but how do i fix? how did i cause?
Mk2 head bed has small spot where coating is scratch off like maybe a small screw fell on it? very very small in size
Any suggestions? Any way to test heat bed (Like hooking directly to 12v line) Am I missing something small in config?
Edited 3 time(s). Last edit at 07/15/2012 04:41PM by bladez.
