Ramps 1.4 has two power inputs, how to connect? August 26, 2013 10:58AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Ramps 1.4 has two power inputs, how to connect? August 27, 2013 02:47PM |
Re: Ramps 1.4 has two power inputs, how to connect? August 27, 2013 07:57PM |
The bottom pair of connectors marked 5A power the stepper drivers and Extruder heater/fan (D9, D10). The source should be rated a minimum of 5A.
The pair of connectors above marked 11A power a Heated Bed, or other output (D8). The source should be rated a minimum 11A (if both power rails are connected to the same supply it should have a minimum rating of 16A).
Re: Ramps 1.4 has two power inputs, how to connect? August 29, 2013 06:45PM |
Re: Ramps 1.4 has two power inputs, how to connect? August 29, 2013 07:02PM |
Re: Ramps 1.4 has two power inputs, how to connect? August 30, 2013 03:35AM |
Re: Ramps 1.4 has two power inputs, how to connect? August 30, 2013 06:47AM |
Re: Ramps 1.4 has two power inputs, how to connect? August 30, 2013 09:11AM |
Re: Ramps 1.4 has two power inputs, how to connect? August 30, 2013 07:18PM |
Re: Ramps 1.4 has two power inputs, how to connect? August 31, 2013 02:28AM |
Re: Ramps 1.4 has two power inputs, how to connect? August 31, 2013 11:10AM |
Re: Ramps 1.4 has two power inputs, how to connect? August 31, 2013 09:36PM |
Re: Ramps 1.4 has two power inputs, how to connect? September 01, 2013 03:52AM |
Re: Ramps 1.4 has two power inputs, how to connect? September 02, 2013 10:19PM |
Re: Ramps 1.4 has two power inputs, how to connect? September 02, 2013 11:06PM |
Re: Ramps 1.4 has two power inputs, how to connect? September 11, 2013 04:36PM |
Re: Ramps 1.4 has two power inputs, how to connect? September 11, 2013 08:21PM |
Re: Ramps 1.4 has two power inputs, how to connect? September 13, 2013 07:38AM |
Re: Ramps 1.4 has two power inputs, how to connect? January 15, 2014 11:31AM |
Re: Ramps 1.4 has two power inputs, how to connect? April 30, 2015 07:59AM |
Re: Ramps 1.4 has two power inputs, how to connect? June 23, 2015 04:44AM |
