Turning Arduino Board off. July 01, 2015 11:56PM |
Re: Turning Arduino Board off. July 02, 2015 01:12AM |
kd6hq
Is it possible to turn the Arduino 2560 board off (besides disconnecting the USB cable) so that is does not power up every time I turn on the computer?
Re: Turning Arduino Board off. July 02, 2015 02:54AM |
Re: Turning Arduino Board off. July 02, 2015 02:32PM |
AndrewBCN
There isn't any easy, simple way to do that. However, note that the Arduino Mega 2560 power consumption is usually around 250mW (1/4W) when powered from USB. The TV in your living room standby power consumption is probably around 5W, so that gives you an idea of how little power the Arduino uses.
enif
You could cut the red 5V wire in your USB cable, so that the Arduino only gets power when you switch on the 12V power supply.
