I am in the process of getting a custom printer up and running and I have hit a snag. I just got the parts machined for a dual extruder setup. After getting everything mounted up and wired, I went into the firmware (Marlin) to add the second extruder. I changed the number of extruders to 2 and added the correct thermister table for the second thermister under temp sensor 1. However, when I connected using Repetier Host, the board is throwing a minimum temperature reset and neither thermistor is getting a reading anymore. I had another ramps board and tried swapping it but I got the same issue.. I have attached my configuration.h file for someone with a little more knowledge to look at. If there are any other settings in Marlin that may cause this that are not in configuration.h please let me know and I will check them as well.
