Y axis not homing (Solved)
Posted by 1nxtmonster
July 20, 2015 01:36PM
I am building an h-bot printer, and am having issues getting the y axis to home. The endstops are normally open and the y endstop is a max endstop. When i press the button to home the y axis in repetier-host, all that the y axis does is move 10mm in the opposite direction of home.
Edit After poking around lots in the firmware, I was able to resolve this issue. However now when the Y axis homes, it says that it is at y=400. Any ideas?
Edit #2: It turns out that in Repetier-Host the bed front edge was defaulted to y=200 for some reason. Changing that to y=0 fixed my issue.
Edited 4 time(s). Last edit at 07/20/2015 08:08PM by 1nxtmonster.
Re: Y axis not homing (Solved)
July 24, 2015 03:46PM
i'm having the same problem when I try the y homing button. Can you explain how you solved it?
July 29, 2015 07:51PM
tamigr
I did what was suggested by RepRot in this thread:
[forums.reprap.org]
