My bed stopped heating. November 10, 2016 06:31PM |
Re: My bed stopped heating. November 10, 2016 06:43PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: My bed stopped heating. November 10, 2016 08:01PM |
Dust
most thermistors reprap uses are normally 100k at 25c and decrease resistance with temperature increasing (ntc negative temperature coefficient)
Re: My bed stopped heating. November 10, 2016 11:08PM |
Re: My bed stopped heating. November 11, 2016 12:38PM |
Dust
Does the controller read room temperature on the bed when its not heating? if so its not thermistor related
If the thermistor is reading room temperature correctly
Dust
Dead io pin (replaced controller board should have fixed that)
Dust
Power wires not connected to heated bed plugs, broken wire somewhere?
Dust
Blown bed fuse (you say you checked this)
Dust
bad cables from heated bed plug to heated bed
Blown heated bed (just check continuity)
Basically stuff a multi meter into the heated bed socket, set the meter to dc voltage and turn on the heated bed (eg M140 S55)
are you seeing voltage?
Re: My bed stopped heating. November 12, 2016 06:46PM |
Re: My bed stopped heating. November 13, 2016 11:06AM |
Re: My bed stopped heating. November 14, 2016 08:20AM |
