Ramps not reading SD card December 19, 2017 12:01PM |
Re: Ramps not reading SD card December 19, 2017 01:54PM |
Re: Ramps not reading SD card December 20, 2017 08:14AM |
Roberts_Clif
Format SD in Fat16 SD Card should be 2GB as max card size is 2GB for a 16bit computer.
When I Purchased my Smart Discount LCD2004 card the Cables were backwards for My Hictop MPX.3 Controller. (Most likely not yours)
Sometimes debris can become lodged inside the SD Card housing, Blow any debris that may have become lodged inside the SD card slot.
[www.arduino.cc]
" You’ll need a SD reader and computer to format your card. The library supports the FAT16 and FAT32 filesystems, but use FAT16 when possible. The process to format is fairly straightforward. "
Re: Ramps not reading SD card December 20, 2017 09:02AM |
Re: Ramps not reading SD card December 21, 2017 07:53AM |
Roberts_Clif
That would in
pins_Ramps.h for Arduino Mega with RAMPS v1.4 (or v1.3) pin assignments
pins_Ramps_old.h for Arduino Mega with RAMPS v1.0, v1.1, v1.2 pin assignments
Re: Ramps not reading SD card December 22, 2017 06:27AM |
Admin Registered: 13 years ago Posts: 7,000 |
