T1 and BED sensor pin invalid output
Posted by beastro
April 09, 2018 01:46PM
I am opening a new thread for this one to divide the issues.
As explained in the thread Blinking LCD I get invalid output for the Bed and T1 sensors. I triple checked the board and even replaced the capacitor for the T1 output suspecting that the problem might lie there. However, the problem persists and what puzzles me most is that T0 returns perfect results.
If I measure voltage between the pins I get.
T1 = 5V
BED= 0.5V
T0 = 0.8V
Clearly some component is failing, but then, why should T1 work? Or would it be the Arduino that is messing things up?
Any ideas?
thanks and regards
Berthold
Re: T1 and BED sensor pin invalid output
April 10, 2018 02:32AM
Are asking over and over again until you get the answer you like?
Dust already wrote it could be a faulty AD-converter, since you switched the thermistors and they seem to work ( cold solder or broken thermistor legs checked?? )
April 10, 2018 02:42AM
Go back to a bare mega and test out the pins A13, A14 and A15
use this basic tutorial [www.arduino.cc]
All you need is to change the pin used in the code (and wire it to that pin)
(you do need to open the serial monitor to see the output)
Edited 1 time(s). Last edit at 04/10/2018 02:45AM by Dust.
April 10, 2018 03:02AM
Dust
Thanks!!
I had checked A13-15 and the voltage is as I wrote above. I have ordered a new Arduino now to see whether that fixes it.
Thanks again for the help!
Berthold
