Y stepper not working, but command tries to move x stepper
Posted by Just_Colin
September 05, 2012 07:41PM
Hello all
I can control the x and z steppers but not the Y. When executing a Y command I can feel and hear a humming from the X stepper as if its trying to move, and I have only 'rarely 'gotten a humming sound from the Y stepper, but no movement, and typically I dont get any response from it.
I've got a reprap huxley with a Sanguinololu board. Everything's connected up and it kinda talks to the computer. I use pronterface.py to control the unit, and have managed to get the 'GET POS, ECHO etc buttons' on the software.
I've swapped the X and Y wires around and can move the Y stepper with the x commands, but then the X stepper doesn't respond, and I get a humming noise (no movement) from the Y stepper. So the motors work fine
I adjusted the potentiometer for the Y stepper when it was connected to the Y Pololu stepper drivers and tried movement with no results. And also when connecting it to the X stepper drivers (so I could control the Y stepper with the X commands) and adjusted the current to the Y stepper to create a nice movement. But this had no effect when reconnecting the wires to the Y driver. And the endstops all work, Ive tested them all by pressing them mid movement causing the stepper to stop.
I'm guessing it's either the software not working properly with the Y commands or the stepper driver is buggered.
I measured the current exiting the pins towards the X and Y stepper with a multimeter when executing movement commands to compare the differences. They seem to be in reverse of each other, and would send signals for the x fine, then suddenly stop sending and I would have to reset or turn the motors off to get it to start sending the commands again :s randomly without executing commands the x would have a reading of 43 (I think 43V, it was on 43 under AC V setting on the 50 position)
OK so overall the Y stepper isnt working, and I'm stumped big time. Do you think its the software messing up the Y commands, I'm not sure how to alter the Y command signal other than the potentiometer?
I'm no expert, but am willing to put in the time
Re: Y stepper not working, but command tries to move x stepper
September 06, 2012 04:40AM
(Since this is a Sanguinololu not a RAMPS, can someone move it to the Sanguino forum?)
If you installed the firmware yourself, check that its Y pin settings (probably in pins.h, configuration.h or similar) match your hardware.
Check for short/open circuits between the processor and Y driver.
The control signals are 0-5V, but the step signals are pulses not sine waves, so your meter's AC range may not be able to measure them properly.
September 06, 2012 01:54PM
My bad confused smiley
I've copied the post to the Sanguino forum.
I can't see any cross connections on the board, and am looking into the software aspect.
Thanks
