Removing d1, checking before I do something
Posted by patrik_g
August 06, 2018 09:30AM
Hello,
I would like to verify something before I modify our reprap board.
I have a pre-assembled reprap 1.4 (with power source) and an arduino mega (with USB connected constantly). Is it required to remove the D1 diode, as there are now 2 power sources for the arduino? And if yes, can I disable it without cutting out the diode?
Re: Removing d1, checking before I do something
August 06, 2018 11:58AM
No, you can leave the diode D1 in, as long as you do not also connect power to the DC-jack of the Arduino Mega.
The Mega has a special circuit built-in to arbitrate between the 5V coming from USB and its own (weak!) 5V regulator.
August 07, 2018 11:35AM
OK, thank you!
