Cannot connect USB and PSU together
Posted by patrik_g
August 08, 2018 10:40AM
Hello,
I have an Arduino mega board with a reprap 1.4. The reprap is powered by a Lascar Electronics PSU 130, 12V. The Arduino is connected with USB. When I upload some software to the Arduino, disconnect USB and power on the PSU, all works as expected (the steppers move, and the PSU reports 12V). When I leave the USB connected, the steppers just make some noise, and the PSU reports 6V. Our setup requires that the USB stays connected for data transmission.
Currently computer and PSU are connected to the same power socket. Is there anything I do wrong here, or something I can test or check?
Edit: I also got the advice to cut the 5V cable of a USB cable. Can that work?
Thanks in advance
Edited 1 time(s). Last edit at 08/08/2018 10:52AM by patrik_g.
VDX
Re: Cannot connect USB and PSU together
August 08, 2018 10:55AM
... maybe there is a voltage difference between the GND of your computer and the PSU, what's causing high currents flowing over the shielding of the USB cable ... this can wreck the USB-port of your computer!
You can search another PSU without this differences or connect a thick wire between computer and PSU GND's to short this out ...
Viktor
August 09, 2018 12:40AM
Atmega has an onboard power selector circuit, which either uses USB power or the onboard 5V regulator. If it doesn't work, all sort of things can happen.
You can try to inspect the Atmega for cold solder or missing parts around the power circuit or replace it with another board.
Cutting off 5V in the USB cable also works, but keep the GND connection intact. Make sure, no one can replace the cable later.
August 21, 2018 11:14AM
Thank you for the answers. In our setup, cutting the usb was the least intrusive, and seems to work well
