This can be many things..
1) you have to have the correct MOTHERBOARD set in configuration.h
2) you need you stepper driver type set in firmware
3) you need working endstops (check with M119)
4) you need the vref on the stepper driver set to match your stepper motors (DO NOT USE A METAL SCREWDRIVER!!!! this nearly always kills the stepper driver)
5) you need 12v on the 12v 5amp power plug
6) you need 3 micro stepping jumpers installed under each stepper driver.
7) you need sane steps/mm settings in firmware
8) you need sane max feed rates in firmware.
and this is all presuming its not binding mechanically
Edited 2 time(s). Last edit at 09/21/2019 08:24AM by Dust.
