I want to move the heatbeds SSR from D8 to D11, which is in the SERVOS area. The reason for this is that I want o connect an additional fan to the D8 PWM output.
First: is it possible to switch the SSR from a SERVOS pin? My SSRs trigger input side starts at 3V, so in theory, that should work.
I have set up the firmware to use D11 for the heatbed, and connected the SSRs + with D11, the - with GND. I am not sure if this is the correct way.
thanks in advance!
Edited 1 time(s). Last edit at 10/03/2019 01:07PM by tobo.
