Somebody help with a copy CONFIGURATION.H / ADV.H and PINS.H
October 21, 2012 05:13PM
Hallo all,
I can't figure it out (for a long time now).
I have a 1gen mendel with RAMPS 1.4 and the nieuw merlin firmware.
I try olmost every firmware that i find, whit no resulds.
in pronterface the steppers will move to 1 direktion.
Can somebody look to my file's or can sent my a copy of yours so that i can compare. manny thangs to all
Aldrik
PINS.H.pdf
CONFIGURATION.ADV.H.pdf
CONFIGURATION.H.pdf
First Gen Mendel made by Adrian Bowyer
Controller: RAMPS 1.4
Extruder: Greg's Wade Universal Accessible Extruder
Firmware :Marlin
MendelMax extra groot
RAMPS 1.4 grafisch display (diy)
Marlin
E3D v6
220V hotbed (diy)
Lang niks in 3Dprinting gedaan, begin nu weer hobby op te pakken.
Weer begonnen met:
Prusa Graber i3 "wood"
RAMPS 1.4 (mks tft28 v1.2 smart touch)
Marlin
E3D extruder v6 lite
Re: Somebody help with a copy CONFIGURATION.H / ADV.H and PINS.H
November 03, 2012 01:40AM
"in pronterface the steppers will move to 1 direktion. "
This may be a problem of Optosensors
For Marlin firmware, Send the Gcode M119 to view the status of the Optosensors, if it shows irregularly you need to change the Endstop settings in config.h just say -1 to 1 or false to true
For example, if the endstop sensed the optosensor the value should be High if you send M119, if it shows low then there should be problem in the codings in config.h and you need to work on Endstop settings to invert the values
November 03, 2012 03:04AM
There is a specific define in one of the config files (at least for marlin) - DISABLE MAX ENDSTOPS. - or something like that, that is commented out in the code. This means that by default the code is looking for maximum end stops on each axis. Thus result is that you will only get one direction of travel - towards home. You need to uncomment this line and make sure this variable is defined if you do not have max endstops
November 03, 2012 02:39PM
Super thanks Gowtham JGR and Jbernardis.
The problem of the X,Y and Z is solved,thanks
Now i have to try to make the extruder motor work. the motor do nothing.
Thanks for the replies
Firmware :Marlin
Marlin
E3D v6
220V hotbed (diy)
Weer begonnen met:
Marlin
November 03, 2012 02:55PM
I just tray a other pololu for the extruder and its working now. YESspinning smiley sticking its tongue out
Firmware :Marlin
Marlin
E3D v6
220V hotbed (diy)
Weer begonnen met:
Marlin
