Is the new Arduino Due compatible with RAMPS 1.4? October 21, 2012 06:00PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? October 21, 2012 07:21PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? October 22, 2012 03:57AM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? October 22, 2012 05:40AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Is the new Arduino Due compatible with RAMPS 1.4? October 29, 2012 08:22AM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? October 30, 2012 12:24AM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? December 06, 2012 06:06PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? December 06, 2012 07:00PM |
Admin Registered: 17 years ago Posts: 7,881 |
Re: Is the new Arduino Due compatible with RAMPS 1.4? December 06, 2012 08:47PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? December 06, 2012 08:58PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 28, 2015 04:38PM |
TopherMan
Does that mean it will work on a 3.3V system, or does that mean it just needs 3V to run, and still needs the 5V for a signal? Either way, it explicitly says on the DRV8825 page that they work on 3.3V or 5V logic.
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 28, 2015 11:22PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 28, 2015 11:32PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 04:39AM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 07:04AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 09:01AM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 09:27AM |
Wurstnase
I don't see any advantage to have ethernet on an embedded system.
When I want a connection to my infrastracture at home I would prefere a wifi-module. I use a raspberry pi II where I can also connect a webcam. Also the upload speed of gcode is much faster.
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 01:00PM |
Exactly what I think. Which is why I created this page in the wiki: OctoGoatBoxQuote
Wurstnase
When I want a connection to my infrastracture at home I would prefer a wifi-module. I use a raspberry pi II where I can also connect a webcam. Also the upload speed of gcode is much faster.
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 29, 2015 03:05PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 12:28PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 12:37PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 01:10PM |
dc42
@AndrwBCN, thanks for your reply. It's a shame Linux isn't flexible enough to support this configuration.
dc42
I am aware that with the standard firmware, the ESP8266 is nowhere near adequate for this application. The question is whether it would be adequate with better firmware. At 80MHz the CPU core should be fast enough, and the 96K of RAM is has should be plenty for the packet buffers. Some variants of the ESP8266 break out the SPI pins, which should be able to provide better bandwidth to the chip than the standard async serial interface.
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 01:20PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 01:51PM |
Re: Is the new Arduino Due compatible with RAMPS 1.4? July 30, 2015 05:46PM |
AndrewBCN
It's not the performance of the CPU in the ESP8266 modules that is questionable nor the amount of RAM available (btw the 96k of ram is almost entirely used by the WiFi functionality, there are just a few k's left for user programs afaik), the fact is that the WiFi protocol itself is not designed for low latency communication. Also, there are some G-code commands that you cannot or should not buffer too deep, etc.
An OctoGoatBox works very well to provide WiFi connectivity for a 3D printer because you basically download the entire STL or G-Code file to the OctoGoatBox and then it does its job, sending the G-code commands in real-time to the printer controller on a relatively low-latency serial link.
