X axis motor not moving under RAMPS 1.4 test firmware November 11, 2012 12:09AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 11, 2012 08:13PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 16, 2012 01:45PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 16, 2012 05:48PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 16, 2012 09:25PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 17, 2012 12:57AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 17, 2012 07:52AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 17, 2012 10:30AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 20, 2012 09:11PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 21, 2012 03:46PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 23, 2012 11:21AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 23, 2012 01:25PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 23, 2012 11:44PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 24, 2012 07:49AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 26, 2012 08:46AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 27, 2012 10:37AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware November 29, 2012 11:44PM |
Re: X axis motor not moving under RAMPS 1.4 test firmware December 02, 2012 09:36AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware December 22, 2012 12:21AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware December 23, 2012 07:26AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware December 23, 2012 11:47AM |
Re: X axis motor not moving under RAMPS 1.4 test firmware December 30, 2012 11:41AM |
Re: I TOO HAVE THE SAME PROBLEM i.e. MY X & Y AXIS DON'T ROTATE March 04, 2015 02:58AM |
Re: I TOO HAVE THE SAME PROBLEM i.e. MY X & Y AXIS DON'T ROTATE March 04, 2015 06:52AM |
rakeshraky
MY X & Y AXIS DOESN'T ROTATE BUT IF I CONNECT TO Z AXIS THE STEPPERS ROTATES BUT IT DON'T MOVES ON X & Y DIRECTION
I AM USING RAMPS 1.4 ARDUINO AND PRONTERFACE
