RAMPS 1.4 as heater port as a DC motor driver??
Posted by softfoot
October 05, 2021 02:06AM
Hi, I have an application for a RAMPS 1.4 board to which it seems idealy suited.
One part of the project has a need to control a small DC vacuum pump and I was thinking about using a relay driven from an IO pin, but I wondered if one of the heater ports could be used.
The motor only takes about 0.5A and being an inductive load would need a couple of clamping diodes to limit the back EMF spikes.
Does this seem a reasonable idea or am I on thin ice ???
Regards,
Dave
Re: RAMPS 1.4 as heater port as a DC motor driver??
October 10, 2021 10:05AM
Has no-one any thoughts on this ??
Dave
September 14, 2022 10:36AM
Hi, just wanted to ask if you found an answer to your question.
I have a ramps board and want to control a similar pump for a pick and place machine.
September 14, 2022 06:11PM
I used two of the ports - one driving a vac pump the other a solonoid valve.
The two loads had a fast diode across the pins the protect from back emf.
It worked very well.
Dave
