Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 01:01PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 01:11PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 06:52PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 07:06PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 07:08PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 08:01PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 06, 2012 09:40PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? December 07, 2012 12:35PM |
Re: Is Ramps / Arduino / Polulu's - Fragile? November 20, 2014 05:00PM |
Cefiar
I replace all the motor connectors on the PCB with Molex locking connectors, to avoid the motors being disconnected accidentally. They use the same type of pins on the PCB, but have a locking arrangement on them. You have to cut off the old connectors from your cable and replace those, but IMO it's worth it. I list that here, as MOST Pololu boards I've seen do not have locking connectors on the motors (not just RAMPS), so it's not specific to RAMPS at all. FWIW: It's even possible to rip the plastic shroud off the locking connector and the standard pins you have on the PCB, and just put the locking part on the existing pins (no desolder/resolder of the PCB pins). I might post some pics later about how to do it if people are interested.
