Replacement for the screw terminals
March 13, 2013 09:22AM
I am looking to replace the screw termials on my ramp 1.4. I havn't put it together yet. I would like to have a male connector soldered to the PCB board, and then the female side on the wire I would like it to be crimpable not soldered or terminal. Both for the supply voltage and the power to the heaters / fans from the mosfats.
I would just use Molex KK connection, but the spacing isn't right (2.54 vs 5.08), and they are problaly under rated for the current.
Anyone have any suggestions?
Re: Replacement for the screw terminals
March 13, 2013 10:12AM
something like these maybe?
[au.element14.com]
March 13, 2013 05:32PM
Molex KK connectors can be found in 5.08mm pitch.
eg: [au.element14.com]
The current for those seems to be inadequate (7A) so you couldn't use it for a heated bed or the input to the PCB unless you were (say) using 24V and appropriate 24V components that didn't draw more than 7A.
March 14, 2013 02:28PM
I spend some time on Mouser.com too. Molex has a SPOX connector that is 5.08mm but it is 7amps. Does anyone know what the family of connections are on the ATX power supply? What I found looking around real quick is that ATX pitch is 4.2mm. So I guess they can't be used with the current ramps1.4.
Is there a reason for 0.2" spacing on the power input?
March 14, 2013 06:21PM
atx are molex mini fit jr
[www.molex.com]
any reason why you dont want screw terminals? how about crimp something onto the end of your cable then insert that into the screw terminal? Thats what I do so i dont wear out the cable and less chance of breaking.
October 04, 2013 08:04AM
> [www.molex.com]
> ifit_jr&channel=products
> chance of breaking.
Thats what bootlace fumerols are for.......
