Bed begins to heat, then stops
April 30, 2013 01:20AM
After a short hiatus in usage of my printer, my bed does not heat.
Stats:
  • Prusa Mendel i2
  • RAMPS 1.4
  • Marlin firmware
  • ATX psu
My extruder heats up normally. When I set a temperature for my bed, it begins heating but around 70C, the MOSFET LED goes out and the temperature plummets. If I disconnect the one or both of the bed wires, LED will come back on until I reconnect the wires. The only way to reset it seems to be to unplug USB and turn off the PSU.
My bed has a resistance of about 1.1 ohms, which seems within normal limits (although confirmation would be great). Any help or ideas will be greatly appreciated.
Re: Bed begins to heat, then stops
April 30, 2013 04:25AM
Maybe your 11A resettable fuse is shutting down. Do you have a fan to cool it?
May 02, 2013 07:42PM
Thanks!! Just checked with my mutimeter and theres no continuity through the fuse when the bed turns off. Its also too hot touch. I could probably jury rig a fan setup to cool it, but now I'm wondering if the fuse cutting out could be indicating a bigger problem. Also, my PSU can go up to 26 amps; is there anything wrong with just shorting over the fuse?
Edited 1 time(s). Last edit at 05/02/2013 10:00PM by thedingwing.
May 03, 2013 12:02AM
If the bed resistance is marginal the fuse will cut off without cooling on the fuse, I have one heated bed that's like this, what's the resistance of the bed?
___________________________________________________________________________
My blog [3dprinterhell.blogspot.com]
May 03, 2013 02:23AM
The resistance is around 1.8 ohms according to my meter. This would put the current at around 6.6 amps.
May 03, 2013 04:39AM
A cooling fan is usually needed on that fuse so just stick one on it - it will cool the stepper drivers at the same time.
Edited 1 time(s). Last edit at 05/03/2013 04:45AM by waitaki.
May 05, 2013 04:30AM
thedingwing
now I'm wondering if the fuse cutting out could be indicating a bigger problem.............is there anything wrong with just shorting over the fuse?
Well, just shorting over the fuse would eliminate this issue but, if there is a bigger problem then it will probably display itself as a nice smoldering pile of electronics if your lucky or a fire if your not!
Please DO NOT bypass it. Even with 12 or 24 volts there is enough amperage around to easily start a fire. The fuse is there for a reason.
Regards
Andy Hodges
