retraction settings not working right May 03, 2013 12:40AM |
Re: retraction settings not working right May 03, 2013 07:02AM |
Re: retraction settings not working right May 03, 2013 03:47PM |
Re: retraction settings not working right May 04, 2013 09:27AM |
Re: retraction settings not working right May 07, 2013 12:43AM |
Re: retraction settings not working right May 07, 2013 01:13AM |
Re: retraction settings not working right May 08, 2013 11:18PM |
Re: retraction settings not working right May 18, 2013 02:29AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 3200/1.25,700} // default steps per unit for ultimaker
#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 40} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {5000,5000,50,5000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: retraction settings not working right May 21, 2013 02:51AM |
