nokia display 4 ramps
Posted by REPRAP SQUAD
June 19, 2013 11:33AM
Why hasnt anyone used the nokia display as an add on screen for the ramps display. It uses 8 pins which is required by ramps. It can be had for about 4$ on ebay. Are there any other lcd dsplay options?
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
Re: nokia display 4 ramps
June 27, 2013 05:12AM
no but i used this without problem in my ramps 1.4 with marlin and is cheap and easy to get work because the library U8GLIB is already configured in the firmware
Graphic LCD
June 27, 2013 08:40AM
Would something like this work. [www.ebay.com] what should I look for. I already have the sd card but I figured it would be easier if it was all in one and im not a big fan of having to solder on little tabs. I want to be able to print stand alone. Can I do that with just the sd card?
June 27, 2013 10:32AM
it work if you add the changes to the firmware to make it compatible with the lcd controller ST7735R, marlin is already compatible with these lcd controller ST7920, ST7565R if you find one lcd with SD card with one of the 2 controller i mention it will be much easier get it work
