Changing LCD Display info
Posted by Mogal
August 07, 2013 10:21PM
I would like to change the LCD display info.
Not sure where to start... So I'll ask!
Right now I have the default display setting:
Nozzle temp ---- Bed temp
Print Time ---- Z Height in mm
(percent?) ---- Percent: SD
Heating Done
Not sure what the '(percent)' is? But I would like to change this to the
number of layers there are in the format of X/Y layers. (Current layer/Total layer)
Also I would like to add a decimal point to the percent completed.
Anyone know how to proceed with these changes?
Thanks!
Chris
Custom all metal CoreXY
- Duet 2 Wifi w/ PanelDue 7i
- 330mm x 360mm x 500mm
- 750w Silicon heater
Custom Mendel90
(Backup printer - Old reliable!) - Sold
Re: Changing LCD Display info
August 09, 2013 03:39PM
hmm...
Alright, I'll dig a little further into it...
Custom Mendel90
August 10, 2013 09:03PM
I've got no help for your actual question, though I'll want to do this, too, eventually. You'd probably be better served posting this over in the Firmware section, because you're going to be making changes to firmware to make it happen.
I can answer your "(percent?)" question. That's a print speed value that you can modify while your object is printing. Want to speed it up? Turn the knob. Slow it down? Other way. I haven't futzed with this except when I accidentally did so, but that's what I'm told it is.
Good luck.
August 11, 2013 05:16PM
Thanks for the info.
I've re-posted this to the firmware section.
Custom Mendel90
