How to set reference voltage RAMPS 1.4/a4988?
Posted by disneytoy
September 11, 2013 01:23PM
Hi!
I'm setting up a new system. My first. I have Wantai 42BYGHW811 steppers 2.5A. and a new Ramps 1.4 and a4988s. I was told:
"These steppers are very good and can handle quite a lot of current. For setting up I always measure the reference voltage on the A4988 module and set them to be 0.45V, this will give you a good starting point for all the axis, it's possible you need to turn it up a little more for the extruder to get some extra force and quick retraction.
But start with 0.45V and all the motors should run just slightly warm, not hot. Don't run motor's too hot."
I have a multimeter. Can some explain how I can set the REFERENCE Voltage properly?
Thank you
Maxi
Re: How to set reference voltage RAMPS 1.4/a4988?
September 11, 2013 06:59PM
Easiest way: Connect one lead of your probe to ground. Connect the other to a small metal screwdriver. Turn the pot on the A4988 board until your multimeter reads 0.45V. Be very careful not to short anything with the screwdriver. RAMPS can be connected only to USB for this, and it is recommended that 12V be disconnected to help avoid shorts.
September 14, 2013 01:47AM
Quick questions:
1) Do I need to load firmware to the Arduino to be able to adjust the driver's voltage?
2) So, no 12 v power, just the USB 5v from the Arduino?
3) can this be done without the motor attached?
4) I looked at the photos but they are blurry. The multimeter gets ground from the rail. and the red probe goes where? In the photos it is not the Pot?
Thanks
Maxi
September 14, 2013 04:28AM
I would ignore the picture at this point.
If the pots have a metal screw, you can usually use that part to do your measurement.
If not, the pot will have 3 pins; 2 pins on one side, and 1 pin on the other. You want the one all by itself.
September 14, 2013 11:51PM
No.
> Arduino?
Yes.
Yes.
As Cefiar said, you can use the pot to do the measurement if it is metal (they usually are).
September 15, 2013 12:21AM
Thank you. The pot is indeed metal. I've just studied theory so far. This is my first hands on, and so many warnings about blowing these chips. i thought from reading to NEVER use a metal screwdriver/ I need a ceramic one which I don't have.
wishe me luck:-)
September 16, 2013 09:54PM
disneytoy Wrote:
> i
> have.
You can use a metal one, just be very careful not to short anything.
September 16, 2013 10:46PM
Thanks. Just don't want the magic smoke:-)
September 05, 2015 01:13AM
Just curious, What would happen if I did short the potentiometer screw on the pololu step stick to something (say a nearby surface mount resistor or cap) while it was powered with 12V. I actually did this yesterday. Now the LCD screen is blank white (full on) with the external power supply switched on. With USB power ONLY, the LCD screen works fine but is dimmer than usual. Also, The arduino board stops getting thermistor readings with the power supply plugged in AND therefore gives the MINTEMP error. However, thermistor readings work when powered with USB. Anybody got a good idea on how to diagnose this? I know its not the RAMPS because I tried using another RAMPS board and it has the same problem. I'm using the DCcduino MEGA 2560 chinese replica DCcEle. Voltage regulator maybe?
Edited 3 time(s). Last edit at 09/05/2015 02:27AM by hedron.
September 05, 2015 03:26PM
You get wrong measurements if you only use USB power. Power the ramps properly with 12v as it is supposed to.
Dont know why other People's renommend as they do, as it will lead you wrong.
Look af the section configuring vref
[www.instructables.com]
Edit
You properly ruined a driver. Try removing it. With ALL power sources turned OFF
Edited 3 time(s). Last edit at 09/05/2015 03:31PM by dintid.
