RAMPS 1.4 with NEMA 23 steppers? November 04, 2013 04:44PM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 04, 2013 07:22PM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 05, 2013 03:43AM |
You might be able to do it, but you will need to make sure that the Pololu drivers are properly cooled with a fan, and I would most definitely put heatsinks on them.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: RAMPS 1.4 with NEMA 23 steppers? November 05, 2013 08:40AM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 05, 2013 09:14AM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 09, 2013 06:54PM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 17, 2013 01:41PM |
uncle_bob
Your 12V steppers are going to need something higher than 12V to run them in micro stepping mode at the speeds we typically run them at. If you are comfortable with 24V power into the Ramps they will do fine. Be very careful about that qualifier, the Mega board is not going to be happy much over 12V without some customization ....
Re: RAMPS 1.4 with NEMA 23 steppers? November 18, 2013 01:39PM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 18, 2013 05:31PM |
Re: RAMPS 1.4 with NEMA 23 steppers? November 18, 2013 07:50PM |
Re: RAMPS 1.4 with NEMA 23 steppers? February 12, 2014 01:35AM |
Re: RAMPS 1.4 with NEMA 23 steppers? February 12, 2014 02:24AM |
