weird retraction
Posted by vinhdinh
weird retraction
December 23, 2013 07:30PM
Hello,
I am having a problem with my extruder retracting properly. I am using repetier 0.83 on a delta style printer. What I notice is when I manually extruder it goes the correct direction. and then when I press retract it moves in the extrude direction then decides to reverse. this happens every time i go from extruder to retract manually.
now during a print, the velocities are much quicker so you really see extrude and then when its time to retract it goes into the extrude direction and doesn't end up reversing. what could this be? I even tested it with no load as well.
[www.youtube.com] take a look at this youtube video. you will see me extruding, and then when I hit retract it would extrude and then retract
Edited 1 time(s). Last edit at 12/23/2013 09:52PM by vinhdinh.
Re: weird retraction
December 26, 2013 05:59PM
This is an exact duplicate of a thread you started in another area. Which one do you want to have the replies in?
